주요 콘텐츠로 건너뛰기
Samsung ATIV Book 9 Speaker Replacement
필요한 것
  1. Samsung ATIV Book 9 Speaker  Replacement, Speaker: 1 단계, 이미지 1/2 Samsung ATIV Book 9 Speaker  Replacement, Speaker: 1 단계, 이미지 2/2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using the Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Speaker  Replacement: 2 단계, 이미지 1/3 Samsung ATIV Book 9 Speaker  Replacement: 2 단계, 이미지 2/3 Samsung ATIV Book 9 Speaker  Replacement: 2 단계, 이미지 3/3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Speaker  Replacement: 3 단계, 이미지 1/3 Samsung ATIV Book 9 Speaker  Replacement: 3 단계, 이미지 2/3 Samsung ATIV Book 9 Speaker  Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
    • Using your hands, remove the battery from the computer.
  4. Samsung ATIV Book 9 Speaker  Replacement: 4 단계, 이미지 1/3 Samsung ATIV Book 9 Speaker  Replacement: 4 단계, 이미지 2/3 Samsung ATIV Book 9 Speaker  Replacement: 4 단계, 이미지 3/3
    • Using a Phillips #1, remove the two 3mm screws, one per speaker.
    • Using the nylon spudger, release the black and red wires that connect the two speakers.
  5. Samsung ATIV Book 9 Speaker  Replacement: 5 단계, 이미지 1/3 Samsung ATIV Book 9 Speaker  Replacement: 5 단계, 이미지 2/3 Samsung ATIV Book 9 Speaker  Replacement: 5 단계, 이미지 3/3
    • Using your hands, remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands remove the speakers from the computer. This may require some force as they are held in place partially by double sided tape.
결론
Phat Tran
회원 가입일: 09/16/18
786 평판
안내서 5개 작성하였습니다
Washington State, Team S2-G5, Hope Fall 2018 Washington State, Team S2-G5, Hope Fall 2018 회원
WSU-HOPE-F18S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 562
