소개
You will be removing the battery from your device. If you haven't done so already, make sure the tablet is completely powered off before continuing.
필요한 것
Remove the stylus from the device.
Place the device screen-up on a hard surface, like a table.
Disconnect the three ribbon cables from the motherboard to free the battery.
Use your finger to lift the flap securing each ZIF connector.
Slide the ribbon cable out and towards you. Now it should be completely detached.
Repeat with the other two cables.
Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 5개
Do you have a battery for the Samsung ATIV Smart PC 700T1C?
If you're lucky, you'll replace the battery & off you go.
Unfortunately, a whole LOT of folks do this, to no avail.
If you pop for the new battery, keep the packing as new as you can in case it's NOT the issue-- at least you might recoup some of the money on Ebay.
After that, also sell your tablet on Ebay for parts because, with some units, you can change out parts all day long & it'll just never run again. Better to count your losses & do some homework this time to hopefully buy a more dependable product.
This series is just shocking at how many people have dead tablets in TWO years!
Shame on Samsung, for not recalling them. I guess they're big enough not to care....
I got my ativ500t last 2014. After a year, the dock is not working anymore. I went to the service center and paid because it's beyond warranty, but they could not solve the problem. They told me the motherboard was broken. After a yr?! Motherboard broken?! Since I cannot do anything about it, I just ditched the dock and used it as a tab, but less frequently. Now, after barely 3 yrs, it will not turn on. Nothing happened to it. It did not get wet or fell. It just fell dead suddenly. I cannot bear to say this, but I was wrong when I purchased this product. I did not get the value I paid for. It is on the pricey tablet pcs, but it did not even last for 3 full yrs considering I do not even use it that much because I have a PC and smartphone. I am very disappointed with samsung and its service center. Shame.
