주요 콘텐츠로 건너뛰기
Samsung ATIV Smart PC 500T Left Speaker Replacement
필요한 것
  1. Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: 1 단계, 이미지 2개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: 1 단계, 이미지 2개 중 2개
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Left Speaker Replacement: 2 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 2 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 3 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 3 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Left Speaker Replacement: 4 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 4 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Left Speaker Replacement: 5 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 5 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Left Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: 6 단계, 이미지 2개 중 1개 Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: 6 단계, 이미지 2개 중 2개
    • Locate the left speaker.
    • The left speaker is labeled with an "L."
    • Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
  7. Samsung ATIV Smart PC 500T Left Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Once the screws have been removed, lift and remove the speaker from the device.
결론
작성자
3다른 기여자 명과 함께
Crystal Dinh
회원 가입일: 09/23/15
1,062 평판
안내서 4개를 작성함
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 1,184
