주요 콘텐츠로 건너뛰기
Samsung ATIV Smart PC 500T Right Speaker Replacement
필요한 것
  1. Samsung ATIV Smart PC 500T Right Speaker Replacement, Backplate: 1 단계, 이미지 1/2 Samsung ATIV Smart PC 500T Right Speaker Replacement, Backplate: 1 단계, 이미지 2/2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Right Speaker Replacement: 2 단계, 이미지 1/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 2 단계, 이미지 2/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 2 단계, 이미지 3/3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: 3 단계, 이미지 1/3 Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: 3 단계, 이미지 2/3 Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: 3 단계, 이미지 3/3
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Right Speaker Replacement: 4 단계, 이미지 1/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 4 단계, 이미지 2/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 4 단계, 이미지 3/3
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Right Speaker Replacement: 5 단계, 이미지 1/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 5 단계, 이미지 2/3 Samsung ATIV Smart PC 500T Right Speaker Replacement: 5 단계, 이미지 3/3
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Right Speaker Replacement, Right Speaker: 6 단계, 이미지 1/2 Samsung ATIV Smart PC 500T Right Speaker Replacement, Right Speaker: 6 단계, 이미지 2/2
    • Locate the right speaker.
    • The right speaker is labeled with an "R."
    • Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
  7. Samsung ATIV Smart PC 500T Right Speaker Replacement: 7 단계, 이미지 1/1
    • Lift and remove the speaker from the device once the screws have been removed.
결론
Marissa Santana
회원 가입일: 09/21/15
279 평판
안내서 1개 작성함
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 935
