주요 콘텐츠로 건너뛰기
Samsung Ace Antenna Replacement
필요한 것
  1. Samsung Ace Antenna Replacement, Battery: 1 단계, 이미지 1/3 Samsung Ace Antenna Replacement, Battery: 1 단계, 이미지 2/3 Samsung Ace Antenna Replacement, Battery: 1 단계, 이미지 3/3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Antenna Replacement: 2 단계, 이미지 1/1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Antenna Replacement: 3 단계, 이미지 1/1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Antenna Replacement, Casing: 4 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Antenna Replacement: 5 단계, 이미지 1/2 Samsung Ace Antenna Replacement: 5 단계, 이미지 2/2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Antenna Replacement: 6 단계, 이미지 1/1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Antenna Replacement: 7 단계, 이미지 1/2 Samsung Ace Antenna Replacement: 7 단계, 이미지 2/2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Antenna Replacement: 8 단계, 이미지 1/1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Antenna Replacement: 9 단계, 이미지 1/2 Samsung Ace Antenna Replacement: 9 단계, 이미지 2/2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Antenna Replacement: 10 단계, 이미지 1/2 Samsung Ace Antenna Replacement: 10 단계, 이미지 2/2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Antenna Replacement: 11 단계, 이미지 1/1
    • Your front casing and front speaker are now released.
  12. Samsung Ace Antenna Replacement, Antenna: 12 단계, 이미지 1/1
    • Remove the two indicated screws (3.9 mm) with a Phillips #00 screwdriver.
  13. Samsung Ace Antenna Replacement: 13 단계, 이미지 1/1
    • Gently pull up the antenna.
    • Be aware of the connected wire along the side of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Garrett Germany
회원 가입일: 04/15/12
24 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-24, Amido Spring 2012 Cal Poly, Team 6-24, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G24
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 2,049
