주요 콘텐츠로 건너뛰기
Samsung Admire Camera Replacement
필요한 것
  1. Samsung Admire Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Samsung Admire Camera Replacement, Remove the Battery: 2 단계, 이미지 1개 중 1개
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  3. Samsung Admire Camera Replacement, Remove the screws: 3 단계, 이미지 3개 중 1개 Samsung Admire Camera Replacement, Remove the screws: 3 단계, 이미지 3개 중 2개 Samsung Admire Camera Replacement, Remove the screws: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
  4. Samsung Admire Camera Replacement, Inside back Cover: 4 단계, 이미지 3개 중 1개 Samsung Admire Camera Replacement, Inside back Cover: 4 단계, 이미지 3개 중 2개 Samsung Admire Camera Replacement, Inside back Cover: 4 단계, 이미지 3개 중 3개
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
  5. Samsung Admire Camera Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Admire Camera Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Admire Camera Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
  6. Samsung Admire Camera Replacement, Camera: 6 단계, 이미지 2개 중 1개 Samsung Admire Camera Replacement, Camera: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Thao Uyen Do
회원 가입일: 01/20/15
926 평판
안내서 4개를 작성함
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 1,791
