주요 콘텐츠로 건너뛰기
Samsung Admire Speaker Replacement
필요한 것
  1. Samsung Admire Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: 2 단계, 이미지 1/1
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: 3 단계, 이미지 1/3 Samsung Admire Speaker Replacement, Remove the screws: 3 단계, 이미지 2/3 Samsung Admire Speaker Replacement, Remove the screws: 3 단계, 이미지 3/3
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: 4 단계, 이미지 1/3 Samsung Admire Speaker Replacement, Inside back cover: 4 단계, 이미지 2/3 Samsung Admire Speaker Replacement, Inside back cover: 4 단계, 이미지 3/3
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Samsung Admire Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Thao Uyen Do
회원 가입일: 01/20/15
896 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 728
