주요 콘텐츠로 건너뛰기
Samsung Alias 2 Logic Board Replacement
필요한 것
  1. Samsung Alias 2 Logic Board Replacement, Battery: 1 단계, 이미지 1/1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Logic Board Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Samsung Alias 2 Logic Board Replacement, Logic Board: 3 단계, 이미지 1/1
    • Remove the (4) 4.2 mm screws from the four corners of the battery slot.
  4. Samsung Alias 2 Logic Board Replacement: 4 단계, 이미지 1/1
    • Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Note: The tab is stuck on there with glue, this is alright, just peel it off.
  5. Samsung Alias 2 Logic Board Replacement: 5 단계, 이미지 1/1
    • Remove the (3) newly uncovered 4.3 mm screws.
  6. Samsung Alias 2 Logic Board Replacement: 6 단계, 이미지 1/1
    • Remove the back outside casing using the plastic opening tool.
    • Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
  7. Samsung Alias 2 Logic Board Replacement: 7 단계, 이미지 1/1
    • Pull up on the yellow tab.
  8. Samsung Alias 2 Logic Board Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect connecting cord using tweezers.
  9. Samsung Alias 2 Logic Board Replacement: 9 단계, 이미지 1/1
    • Disconnect rectangular ribbon.
  10. Samsung Alias 2 Logic Board Replacement: 10 단계, 이미지 1/1
    • Remove logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris
회원 가입일: 04/16/11
133 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 회원
CPSU-MANESS-S11S12G35
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,743
