주요 콘텐츠로 건너뛰기
Samsung Alias 2 Speaker Replacement
필요한 것
  1. Samsung Alias 2 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
  3. Samsung Alias 2 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the two (4.1 mm) screws down the screen.
  4. Samsung Alias 2 Speaker Replacement: 4 단계, 이미지 1/2 Samsung Alias 2 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the upper casing with a plastic opening tools.
  5. Samsung Alias 2 Speaker Replacement: 5 단계, 이미지 1/1
    • Use soldering iron to melt, and remove soldering joints of the speaker.
  6. Samsung Alias 2 Speaker Replacement: 6 단계, 이미지 1/2 Samsung Alias 2 Speaker Replacement: 6 단계, 이미지 2/2
    • Use tweezers to remove the speaker from its place.
    • Note: There are two speakers. Make sure you know which one is broken before removing it.
  7. Samsung Alias 2 Speaker Replacement: 7 단계, 이미지 1/2 Samsung Alias 2 Speaker Replacement: 7 단계, 이미지 2/2
    • Use tweezers to insert the new speaker into the speaker slot.
  8. Samsung Alias 2 Speaker Replacement: 8 단계, 이미지 1/1
    • Solder a speaker ribbon to the logic board.
    • Note: be careful to match the right polarity before you solder.
결론
Chris
회원 가입일: 04/16/11
133 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 회원
CPSU-MANESS-S11S12G35
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,094
