주요 콘텐츠로 건너뛰기
Samsung BD-D5500 Disassembly
필요한 것
  1. Samsung BD-D5500 Disassembly, Samsung BD-D5500 Disassembly: 1 단계, 이미지 1/1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disassembly: 2 단계, 이미지 1/2 Samsung BD-D5500 Disassembly: 2 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kenya Wilson
회원 가입일: 01/29/18
226 평판
안내서 2개 작성하였습니다
University of Alabama, Team S2-G5, Bedsole Spring 2018 University of Alabama, Team S2-G5, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S2G5
4 회원들
안내서 6개 작성하였습니다
댓글 2개
I had trouble putting the vent side back in, it didn’t fit correcly. If it wasn’t late I would of done a proper disassemble. Plus it’s not a full one where it shows taking off the side panels and the front panel to access the touch screen.
if you are having issues with the model shutting off and on, you don’t have to remove the front panel you can get access to the gray plug after you take off all the top and side panels.
mush god - 답글
I can’t edit my comment….
brown plug not gray. In Step 3 picture once you reach there just unplug the white wire at the front of the player than you can easily unplug the brown plug to disable the touch buttons. Than just reconnect the white wire and reassemble.
mush god - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 2,740
