주요 콘텐츠로 건너뛰기
Samsung BD-E5400 Power Cord Replacement
필요한 것
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: 1 단계, 이미지 1/2 Samsung BD-E5400 Power Cord Replacement, Outer Cover: 1 단계, 이미지 2/2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: 2 단계, 이미지 1/1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: 3 단계, 이미지 1/2 Samsung BD-E5400 Power Cord Replacement, Power Cord: 3 단계, 이미지 2/2
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: 4 단계, 이미지 1/3 Samsung BD-E5400 Power Cord Replacement: 4 단계, 이미지 2/3 Samsung BD-E5400 Power Cord Replacement: 4 단계, 이미지 3/3
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
결론
Cameron Herring
회원 가입일: 08/28/18
306 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G3, Arle Fall 2018 IUPUI, Team S1-G3, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 333
