주요 콘텐츠로 건너뛰기
Samsung BD-E5400 Wi-Fi Card Replacement
필요한 것
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: 1 단계, 이미지 1/2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: 1 단계, 이미지 2/2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 3 단계, 이미지 1/3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 3 단계, 이미지 2/3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: 3 단계, 이미지 3/3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
결론
Cameron Herring
회원 가입일: 08/28/18
306 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G3, Arle Fall 2018 IUPUI, Team S1-G3, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 278
