주요 콘텐츠로 건너뛰기
Samsung BD-F5700 DC Power Board Replacement
필요한 것
  1. Samsung BD-F5700 DC Power Board Replacement, DC Power Board: 1 단계, 이미지 1/1
    • Remove the three 10mm screws with a Phillips #0 screwdriver.
    • Pry the top off with a plastic opening tool.
  2. Samsung BD-F5700 DC Power Board Replacement: 2 단계, 이미지 1/1
    • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  3. Samsung BD-F5700 DC Power Board Replacement: 3 단계, 이미지 1/1
    • Lift up the power cord at its base to remove it.
  4. Samsung BD-F5700 DC Power Board Replacement: 4 단계, 이미지 1/1
    • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  5. Samsung BD-F5700 DC Power Board Replacement: 5 단계, 이미지 1/1
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    • Grip the blue tab attached to the base and pull upwards.
  6. Samsung BD-F5700 DC Power Board Replacement: 6 단계, 이미지 1/1
    • Grip the edges of the motherboard and pull upwards to remove.
결론
samer odeh
회원 가입일: 02/13/18
313 평판
안내서 1개 작성함
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 370
