소개
This guide will show how the replacement of the disk reader is done.
부품
지정된 부품이 없습니다.
Use Phillips 0 Screwdriver to remove two (2) 10 mm rear screws.
Use a plastic prying tool to help separate the top plastic casing from the bottom metal casing.
Remove the two 10mm screws with a Phillips #1 screwdriver.
Separate the two pieces with a plastic opening tool.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
