주요 콘텐츠로 건너뛰기
Samsung BD-F5700 Disc Tray Replacement
필요한 것
  1. Samsung BD-F5700 Disc Tray  Replacement, Disc Tray: 1 단계, 이미지 1/2 Samsung BD-F5700 Disc Tray  Replacement, Disc Tray: 1 단계, 이미지 2/2
    • Remove the two 10mm screws with a Phillips #1 screwdriver.
    • Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
  2. Samsung BD-F5700 Disc Tray  Replacement: 2 단계, 이미지 1/3 Samsung BD-F5700 Disc Tray  Replacement: 2 단계, 이미지 2/3 Samsung BD-F5700 Disc Tray  Replacement: 2 단계, 이미지 3/3
    • Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard.
    • If it feels stuck, wiggle it while pulling gently to coerce it out.
  3. Samsung BD-F5700 Disc Tray  Replacement: 3 단계, 이미지 1/1
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  4. Samsung BD-F5700 Disc Tray  Replacement: 4 단계, 이미지 1/3 Samsung BD-F5700 Disc Tray  Replacement: 4 단계, 이미지 2/3 Samsung BD-F5700 Disc Tray  Replacement: 4 단계, 이미지 3/3
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
결론
Livan Perez
회원 가입일: 02/15/18
303 평판
안내서 2개 작성하였습니다
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 324
