주요 콘텐츠로 건너뛰기
Samsung BD-F5900 DVD Disc Tray Replacement
필요한 것
  1. Samsung BD-F5900 DVD Disc Tray Replacement, Top Cover: 1 단계, 이미지 1/1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 DVD Disc Tray Replacement: 2 단계, 이미지 1/1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 DVD Disc Tray Replacement, DVD Disc Tray: 3 단계, 이미지 1/1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  4. Samsung BD-F5900 DVD Disc Tray Replacement: 4 단계, 이미지 1/1
    • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  5. Samsung BD-F5900 DVD Disc Tray Replacement: 5 단계, 이미지 1/1
    • Push two small prongs on either side of disc tray inwards and push disc tray forward.
  6. Samsung BD-F5900 DVD Disc Tray Replacement: 6 단계, 이미지 1/1
    • Remove disc tray
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Louis McKean
회원 가입일: 10/18/17
528 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G21
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 659
