주요 콘텐츠로 건너뛰기
Samsung BD-F5900 Power Supply Replacement
필요한 것
  1. Samsung BD-F5900 Power Supply Replacement, Top Cover: 1 단계, 이미지 1/1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Power Supply Replacement: 2 단계, 이미지 1/1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Power Supply Replacement, Power Supply: 3 단계, 이미지 1/2 Samsung BD-F5900 Power Supply Replacement, Power Supply: 3 단계, 이미지 2/2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Power Supply Replacement: 4 단계, 이미지 1/1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Power Supply Replacement: 5 단계, 이미지 1/3 Samsung BD-F5900 Power Supply Replacement: 5 단계, 이미지 2/3 Samsung BD-F5900 Power Supply Replacement: 5 단계, 이미지 3/3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
결론
Louis McKean
회원 가입일: 10/18/17
528 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G21
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 231
