주요 콘텐츠로 건너뛰기
Samsung BD-F5900 WiFi Module Replacement
필요한 것
  1. Samsung BD-F5900 WiFi Module Replacement, Top Cover: 1 단계, 이미지 1/1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 WiFi Module Replacement: 2 단계, 이미지 1/1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 WiFi Module Replacement, WiFi Module: 3 단계, 이미지 1/1
    • Disconnect the WiFi board cable connector from the main logic board
  4. Samsung BD-F5900 WiFi Module Replacement: 4 단계, 이미지 1/1
    • Using a #1 Phillips head screwdriver, remove the 7.5 mm screw.
    • Slightly tilt the WiFi module sideways to remove from chassis.
결론
Louis McKean
회원 가입일: 10/18/17
528 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G21
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 208
