주요 콘텐츠로 건너뛰기
Samsung BD-F7500 Blu-ray Player Disc Reader Replacement
필요한 것
  1. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Tray: 1 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Tray: 1 단계, 이미지 2/2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 2 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 2 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 2 단계, 이미지 3/3
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 3 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 3 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 3 단계, 이미지 3/3
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 4 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 4 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 4 단계, 이미지 3/3
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
  5. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement, Disc Reader: 5 단계, 이미지 1/1
    • Remove spring on the side of the disc tray by carefully pulling it off its hook.
  6. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 6 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 6 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 6 단계, 이미지 3/3
    • Locate the two black tabs, found at the end of the black bar across the disc tray. The tabs are located on the opposite side of the spring.
    • While simultaneously pushing both tabs in, lift up the black plastic bar.
    • Using a spudger, it is helpful to push in the tab as well as using the spudger as a lever.
    • The tabs are weak, constant pressure is the key, not overpowering force.
  7. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 7 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 7 단계, 이미지 2/2
    • To remove the ribbon cable, flip down the black bar located on the connector.
  8. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 8 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 8 단계, 이미지 2/2
    • Remove four (4) 10 mm screws using a phillips head #J1 screwdriver.
    • Remove the small metal bars by pulling it outwards.
    • The metal bars should have some wiggle room allowing it to be pulled out. It may be handy to push it up from underneath the disc tray.
  9. Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 9 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Disc Reader Replacement: 9 단계, 이미지 2/2
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
    • The laser may need to be turned on its side as its pulled out.
결론
James McMicheal
회원 가입일: 09/28/17
520 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 2,002
