주요 콘텐츠로 건너뛰기
Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
필요한 것
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: 1 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: 1 단계, 이미지 2/2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 2 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 2 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 2 단계, 이미지 3/3
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 3 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 3 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 3 단계, 이미지 3/3
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 4 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 4 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: 4 단계, 이미지 3/3
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
결론
James McMicheal
회원 가입일: 09/28/17
520 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 686
