주요 콘텐츠로 건너뛰기
Samsung BD-F7500 Blu-ray Player Power Cord Replacement
필요한 것
  1. Samsung BD-F7500 Blu-ray Player Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 2 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 2 단계, 이미지 2/2
    • While firmly gripping the gray, metal base, lift the black plastic cover off the device.
    • The case is clamped onto the edges of the device, so bending of the plastic top will be required. Don't be afraid to use some force, it is unlikely that it will break.
    • Be careful not to tear ribbon cables attached to the outer cover.
  3. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 3 단계, 이미지 1/3 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 3 단계, 이미지 2/3 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 3 단계, 이미지 3/3
    • Using the Philips head #J1 bit, remove the three (3) 10 mm screws that secure the plastic cover.
    • Gently remove the plastic cover.
  4. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 4 단계, 이미지 1/2 Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 4 단계, 이미지 2/2
    • To remove the power cord, gently apply pressure to the tab located at the base of the cord and lift the cord with your fingers.
  5. Samsung BD-F7500 Blu-ray Player Power Cord Replacement: 5 단계, 이미지 1/1
    • Locate the black plastic tab located on the power cord.
    • Using a spudger, gently insert the tool into the crack, to allow space for the wire to slide out.
    • Pull the plastic tab off of the wire, so that it can be placed on the replacement power cord.
결론
James McMicheal
회원 가입일: 09/28/17
520 평판
안내서 5개 작성하였습니다
댓글 한 개
Where can one find a replacement cord?
Jane Grey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 706
