주요 콘텐츠로 건너뛰기
Samsung BD-H5100 Disk Reader Replacement
필요한 것
  1. Samsung BD-H5100 Disk Reader Replacement, Disk Reader: 1 단계, 이미지 1/1
    • Use the Phillips Head #2 screwdriver to remove the three 10 mm screws on the back panel.
  2. Samsung BD-H5100 Disk Reader Replacement: 2 단계, 이미지 1/3 Samsung BD-H5100 Disk Reader Replacement: 2 단계, 이미지 2/3 Samsung BD-H5100 Disk Reader Replacement: 2 단계, 이미지 3/3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Disk Reader Replacement: 3 단계, 이미지 1/2 Samsung BD-H5100 Disk Reader Replacement: 3 단계, 이미지 2/2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Disk Reader Replacement: 4 단계, 이미지 1/1
    • Remove the two 7.5 mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Disk Reader Replacement: 5 단계, 이미지 1/2 Samsung BD-H5100 Disk Reader Replacement: 5 단계, 이미지 2/2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Disk Reader Replacement: 6 단계, 이미지 1/1
    • Flip the disk tray upside down.
  7. Samsung BD-H5100 Disk Reader Replacement: 7 단계, 이미지 1/1
    • Use the Phillips Head #00 screwdriver to remove the four 6.2 mm corner screws.
  8. Samsung BD-H5100 Disk Reader Replacement: 8 단계, 이미지 1/1
    • Flip the disk reader up like a flip phone.
    • Be careful not to break the ribbon.
  9. Samsung BD-H5100 Disk Reader Replacement: 9 단계, 이미지 1/2 Samsung BD-H5100 Disk Reader Replacement: 9 단계, 이미지 2/2
    • Pull the ribbon out gently from one corner by the blue tab.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mira Patel
회원 가입일: 10/11/16
580 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-2, Leahy Fall 2016 USF Tampa, Team 1-2, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 12
전체 시간: 632
