주요 콘텐츠로 건너뛰기
Samsung BD-H5100 Media Controls Replacement
필요한 것
  1. Samsung BD-H5100 Media Controls Replacement, Media Controls: 1 단계, 이미지 1/1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Media Controls Replacement: 2 단계, 이미지 1/3 Samsung BD-H5100 Media Controls Replacement: 2 단계, 이미지 2/3 Samsung BD-H5100 Media Controls Replacement: 2 단계, 이미지 3/3
    • Use the plastic spudger to pry open the top panel from the center tab.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Media Controls Replacement: 3 단계, 이미지 1/2 Samsung BD-H5100 Media Controls Replacement: 3 단계, 이미지 2/2
    • Pull the ribbon gently from one corner by the blue tab to remove it.
  4. Samsung BD-H5100 Media Controls Replacement: 4 단계, 이미지 1/1
    • Use a Phillips Head #00 to unscrew the two 7mm screws on the media controls.
  5. Samsung BD-H5100 Media Controls Replacement: 5 단계, 이미지 1/1
    • Remove the white cover from the media controls.
결론
Mira Patel
회원 가입일: 10/11/16
580 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-2, Leahy Fall 2016 USF Tampa, Team 1-2, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 239
