주요 콘텐츠로 건너뛰기
Samsung BD-H5100 Motherboard Replacement
필요한 것
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: 2 단계, 이미지 1/3 Samsung BD-H5100 Motherboard Replacement: 2 단계, 이미지 2/3 Samsung BD-H5100 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: 3 단계, 이미지 1/2 Samsung BD-H5100 Motherboard Replacement: 3 단계, 이미지 2/2
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: 5 단계, 이미지 1/2 Samsung BD-H5100 Motherboard Replacement: 5 단계, 이미지 2/2
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: 6 단계, 이미지 1/2 Samsung BD-H5100 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung BD-H5100 Motherboard Replacement: 7 단계, 이미지 2/2
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: 8 단계, 이미지 1/1
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: 9 단계, 이미지 1/1
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: 10 단계, 이미지 1/1
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
결론
Mira Patel
회원 가입일: 10/11/16
580 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-2, Leahy Fall 2016 USF Tampa, Team 1-2, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 520
