주요 콘텐츠로 건너뛰기
Samsung BD-JM57C Motherboard Replacement
필요한 것
  1. Samsung BD-JM57C Motherboard Replacement, Top Cover: 1 단계, 이미지 1/2 Samsung BD-JM57C Motherboard Replacement, Top Cover: 1 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Motherboard Replacement, Disc Drive: 2 단계, 이미지 1/2 Samsung BD-JM57C Motherboard Replacement, Disc Drive: 2 단계, 이미지 2/2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Motherboard Replacement: 3 단계, 이미지 1/2 Samsung BD-JM57C Motherboard Replacement: 3 단계, 이미지 2/2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Motherboard Replacement, Power Cord: 4 단계, 이미지 1/2 Samsung BD-JM57C Motherboard Replacement, Power Cord: 4 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  5. Samsung BD-JM57C Motherboard Replacement: 5 단계, 이미지 1/1
    • Push in the small white lever and pull it towards you to release the cord.
  6. Samsung BD-JM57C Motherboard Replacement: 6 단계, 이미지 1/1
    • Move the power cord out from under the metal tab on the side of the case.
  7. Samsung BD-JM57C Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  8. Samsung BD-JM57C Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  9. Samsung BD-JM57C Motherboard Replacement: 9 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  10. Samsung BD-JM57C Motherboard Replacement: 10 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
결론
Abby Hudson
회원 가입일: 01/14/20
637 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 8
전체 시간: 488
