주요 콘텐츠로 건너뛰기
Samsung BD-JM57C Power Cord Replacement
필요한 것
  1. Samsung BD-JM57C Power Cord Replacement, Top Cover: 1 단계, 이미지 1/2 Samsung BD-JM57C Power Cord Replacement, Top Cover: 1 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Power Cord Replacement, Disc Drive: 2 단계, 이미지 1/2 Samsung BD-JM57C Power Cord Replacement, Disc Drive: 2 단계, 이미지 2/2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Power Cord Replacement: 3 단계, 이미지 1/2 Samsung BD-JM57C Power Cord Replacement: 3 단계, 이미지 2/2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Power Cord Replacement, WiFi Card: 4 단계, 이미지 1/2 Samsung BD-JM57C Power Cord Replacement, WiFi Card: 4 단계, 이미지 2/2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Power Cord Replacement, Power Cord: 5 단계, 이미지 1/2 Samsung BD-JM57C Power Cord Replacement, Power Cord: 5 단계, 이미지 2/2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Power Cord Replacement: 6 단계, 이미지 1/1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Power Cord Replacement: 7 단계, 이미지 1/1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Power Cord Replacement: 8 단계, 이미지 1/1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
결론
Abby Hudson
회원 가입일: 01/14/20
637 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 158
