주요 콘텐츠로 건너뛰기
Samsung BN59-01199F Keypad Replacement
필요한 것
  1. Samsung BN59-01199F Keypad Replacement, Keypad: 1 단계, 이미지 1/1
    • Remove the batteries before you disassemble the remote.
    • Use an opening pick in the seam of the controller and work it around the perimeter.
    • With the opening pick, scrape and remove the glue and undo the clips holding the top and bottom of the remote together.
  2. Samsung BN59-01199F Keypad Replacement: 2 단계, 이미지 1/2 Samsung BN59-01199F Keypad Replacement: 2 단계, 이미지 2/2
    • Use additional opening picks to keep the seam open.
    • Don't use a screwdriver or metal spudger for prying especially because the motherboard is directly underneath and could be damaged in the process.
    • Use a spudger or opening pick to work your way around the seam of the remote.
    • Separate the two sides of the remote.
  3. Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 1/3 Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 2/3 Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 3/3
    • Remove the motherboard, the plastic button case, and finally the buttons from the plastic case.
    • Place the new keypad into the keypad holder and press to make sure it's set in securely.
  4. Samsung BN59-01199F Keypad Replacement: 4 단계, 이미지 1/2 Samsung BN59-01199F Keypad Replacement: 4 단계, 이미지 2/2
    • After replacing the rubber keypad, reassemble the remote.
    • Make sure to insert the light in the small hole during reassembly.
  5. Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 1/3 Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 2/3 Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 3/3
    • When joining the two halves of the remote together line the spring up with the appropriate slot.
    • Carefully, press the two parts of the remote together.
  6. Samsung BN59-01199F Keypad Replacement: 6 단계, 이미지 1/1
    • Make sure the remote is working after you put it back together and replaced the batteries.
결론
yeisom Garrido
회원 가입일: 10/26/22
183 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-46, Briggs Fall 2022 CSU Los Angeles, Team 1-46, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S1G46
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 48
전체 시간: 527
