주요 콘텐츠로 건너뛰기
Samsung BN59-01199F Keypad Replacement
필요한 것
  1. Samsung BN59-01199F Keypad Replacement, Keypad: 1 단계, 이미지 1개 중 1개
    • Remove the batteries before you disassemble the remote.
    • Use an opening pick in the seam of the controller and work it around the perimeter.
    • With the opening pick, scrape and remove the glue and undo the clips holding the top and bottom of the remote together.
  2. Samsung BN59-01199F Keypad Replacement: 2 단계, 이미지 2개 중 1개 Samsung BN59-01199F Keypad Replacement: 2 단계, 이미지 2개 중 2개
    • Use additional opening picks to keep the seam open.
    • Don't use a screwdriver or metal spudger for prying especially because the motherboard is directly underneath and could be damaged in the process.
    • Use a spudger or opening pick to work your way around the seam of the remote.
    • Separate the two sides of the remote.
  3. Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 3개 중 1개 Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 3개 중 2개 Samsung BN59-01199F Keypad Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the motherboard, the plastic button case, and finally the buttons from the plastic case.
    • Place the new keypad into the keypad holder and press to make sure it's set in securely.
  4. Samsung BN59-01199F Keypad Replacement: 4 단계, 이미지 2개 중 1개 Samsung BN59-01199F Keypad Replacement: 4 단계, 이미지 2개 중 2개
    • After replacing the rubber keypad, reassemble the remote.
    • Make sure to insert the light in the small hole during reassembly.
  5. Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 3개 중 1개 Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 3개 중 2개 Samsung BN59-01199F Keypad Replacement: 5 단계, 이미지 3개 중 3개
    • When joining the two halves of the remote together line the spring up with the appropriate slot.
    • Carefully, press the two parts of the remote together.
  6. Samsung BN59-01199F Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Make sure the remote is working after you put it back together and replaced the batteries.
결론
작성자
1다른 기여자 명과 함께
yeisom Garrido
회원 가입일: 10/26/22
183 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 59
전체 시간: 1,311
