주요 콘텐츠로 건너뛰기
Samsung BlackJack II Antenna Replacement
필요한 것
  1. Samsung BlackJack II Antenna Replacement, Battery: 1 단계, 이미지 1/3 Samsung BlackJack II Antenna Replacement, Battery: 1 단계, 이미지 2/3 Samsung BlackJack II Antenna Replacement, Battery: 1 단계, 이미지 3/3
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Samsung BlackJack II Antenna Replacement: 2 단계, 이미지 1/3 Samsung BlackJack II Antenna Replacement: 2 단계, 이미지 2/3 Samsung BlackJack II Antenna Replacement: 2 단계, 이미지 3/3
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  3. Samsung BlackJack II Antenna Replacement, Back Casing: 3 단계, 이미지 1/2 Samsung BlackJack II Antenna Replacement, Back Casing: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
  4. Samsung BlackJack II Antenna Replacement: 4 단계, 이미지 1/1
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
  5. Samsung BlackJack II Antenna Replacement: 5 단계, 이미지 1/3 Samsung BlackJack II Antenna Replacement: 5 단계, 이미지 2/3 Samsung BlackJack II Antenna Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
  6. Samsung BlackJack II Antenna Replacement, Front Casing: 6 단계, 이미지 1/2 Samsung BlackJack II Antenna Replacement, Front Casing: 6 단계, 이미지 2/2
    • Pry apart the plastic tabs along the edges of the phone.
    • Separate the front panel from the main body of the phone using your fingers.
  7. Samsung BlackJack II Antenna Replacement, Antenna: 7 단계, 이미지 1/1
    • Remove the two 4.0 mm screws, one silver and one black, from both ends of the antenna using the Phillips 00 screwdriver.
  8. Samsung BlackJack II Antenna Replacement: 8 단계, 이미지 1/1
    • To remove the antenna, disconnect the white antenna cable that connects it to the main circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan Rumsey
회원 가입일: 01/30/13
8 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-1, Maness Winter 2013 Cal Poly, Team 20-1, Maness Winter 2013 회원
CPSU-MANESS-W13S20G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 453
