주요 콘텐츠로 건너뛰기
Samsung Blackjack Back Phone Casing Replacement
필요한 것
  1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: 1 단계, 이미지 1/3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: 1 단계, 이미지 2/3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: 1 단계, 이미지 3/3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Back Phone Casing Replacement, Battery: 2 단계, 이미지 1/2 Samsung Blackjack Back Phone Casing Replacement, Battery: 2 단계, 이미지 2/2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Back Phone Casing Replacement, SIM Card: 3 단계, 이미지 1/3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: 3 단계, 이미지 2/3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: 3 단계, 이미지 3/3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: 4 단계, 이미지 1/2 Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: 4 단계, 이미지 2/2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Back Phone Casing Replacement: 5 단계, 이미지 1/3 Samsung Blackjack Back Phone Casing Replacement: 5 단계, 이미지 2/3 Samsung Blackjack Back Phone Casing Replacement: 5 단계, 이미지 3/3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
결론
Kristin Manna
회원 가입일: 10/22/12
29 평판
안내서 10개 작성하였습니다
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 회원
CLEM-BENSON-F12S14G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 496
