소개
Use this guide to replace the motherboard.
Use the spudger to remove the rubber stoppers from the top of the cover.
Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
Use the spudger to unsnap the black rectangular connection from the motherboard.
Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
