주요 콘텐츠로 건너뛰기
Samsung Blackjack Speaker Replacement
필요한 것
  1. Samsung Blackjack Speaker Replacement, Battery Cover: 1 단계, 이미지 1/3 Samsung Blackjack Speaker Replacement, Battery Cover: 1 단계, 이미지 2/3 Samsung Blackjack Speaker Replacement, Battery Cover: 1 단계, 이미지 3/3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Speaker Replacement, Battery: 2 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement, Battery: 2 단계, 이미지 2/2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Speaker Replacement, SIM Card: 3 단계, 이미지 1/3 Samsung Blackjack Speaker Replacement, SIM Card: 3 단계, 이미지 2/3 Samsung Blackjack Speaker Replacement, SIM Card: 3 단계, 이미지 3/3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Speaker Replacement, Back Phone Casing: 4 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement, Back Phone Casing: 4 단계, 이미지 2/2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Speaker Replacement: 5 단계, 이미지 1/3 Samsung Blackjack Speaker Replacement: 5 단계, 이미지 2/3 Samsung Blackjack Speaker Replacement: 5 단계, 이미지 3/3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Speaker Replacement, Motherboard: 6 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement, Motherboard: 6 단계, 이미지 2/2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  7. Samsung Blackjack Speaker Replacement: 7 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement: 7 단계, 이미지 2/2
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  8. Samsung Blackjack Speaker Replacement: 8 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement: 8 단계, 이미지 2/2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
  9. Samsung Blackjack Speaker Replacement, Speaker: 9 단계, 이미지 1/2 Samsung Blackjack Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Use the spudger to wedge between the speaker and the speaker's casing.
    • Use the spudger to pry on the speaker until it comes free from the casing.
결론
Kristin Manna
회원 가입일: 10/22/12
29 평판
안내서 10개 작성하였습니다
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 회원
CLEM-BENSON-F12S14G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 396
