주요 콘텐츠로 건너뛰기
Samsung Blast Back Cover Replacement
필요한 것
  1. Samsung Blast Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: 2 단계, 이미지 1/1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: 3 단계, 이미지 1/1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: 4 단계, 이미지 1/1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph
회원 가입일: 04/10/14
129 평판
안내서 1개 작성함
University of Maryland, Team 1-1, Calloway Spring 2014 University of Maryland, Team 1-1, Calloway Spring 2014 회원
UMD-CALLOWAY-S14S1G1
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 184
