이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Remove the battery cover by sliding the back panel up. This will expose the battery.
Lift up the top portion of the battery and pull it out.
Next, slide the sim card out of its socket and set it aside.
Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
Remove the case by prying around the edges.
Use a prying tool to detach the motherboard from main body.
Carefully detach the motherboard from the two connectors.
Slide the keyboard straight up to free it from its alignment pins.
