이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery cover by sliding the back panel up. This will expose the battery.
Lift up the top portion of the battery and pull it out.
Next, slide the sim card out of its socket and set it aside.
Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
Remove the case by prying around the edges.
Use a prying tool to detach the motherboard from main body.
Carefully detach the motherboard from the two connectors.
