주요 콘텐츠로 건너뛰기
Samsung Blast Motherboard Replacement
필요한 것
  1. Samsung Blast Motherboard  Replacement, Motherboard: 1 단계, 이미지 1/2 Samsung Blast Motherboard  Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the battery cover by pushing it upwards.
  2. Samsung Blast Motherboard  Replacement: 2 단계, 이미지 1/1
    • Take out the battery.
  3. Samsung Blast Motherboard  Replacement: 3 단계, 이미지 1/1
    • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
    • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
  4. Samsung Blast Motherboard  Replacement: 4 단계, 이미지 1/1
    • Pull off the back cover of the phone.
  5. Samsung Blast Motherboard  Replacement: 5 단계, 이미지 1/2 Samsung Blast Motherboard  Replacement: 5 단계, 이미지 2/2
    • Remove the volume and camera buttons by pulling them out.
    • Put the buttons aside until it is time to reassemble the phone.
  6. Samsung Blast Motherboard  Replacement: 6 단계, 이미지 1/1
    • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
  7. Samsung Blast Motherboard  Replacement: 7 단계, 이미지 1/2 Samsung Blast Motherboard  Replacement: 7 단계, 이미지 2/2
    • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paige Weinstein
회원 가입일: 02/11/14
1 평판
안내서 1개 작성함
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 306
