이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Here is the Samsung SCH-U380 Brightside.
Turn it over to gain access to the battery.
Remove the backcover by simply pulling it off the phone from the top down
Remove the battery
Remove the six Phillips screws from the back frame
All six screws are identical M1.5X3
Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
Continue to slide the tool along the slot until you feel the plastic locks disengage
Once all locks have released, the bottom frame can simply be removed.
Remove the two Phillips screws from the EMI shield.
Both screws are identical M1.5X2
Remove the EMI shield
Detach the LCD connector.
Remove the logic board
Slide the front case assembly to the side, remove the keyboard membrane simply by lifting it out.
Remove the flex cable from the assembly. It is adhered with some rubber cement and may require a bit of pull
move the flex to the side
Remove the six Phillips screws from the assembly
All six screws are M1x1
The assembly is now loose and can be gently lifted up.
Carefully guide the flex cable through the assembly. It only fits one way.
Remove the four Phillips screws from the slider case
All four screws are identical M1x2
Here are all screws removed.
Insert a plastic opening tool, or similar, to separate the sliding assembly from the case
Guide the opening tool all the way around the slider. This will release the clips that hold it in place.
With the clips released, the sliding mechanism can be lifted up, careful to not rip the flex
Guide the flex through the sliding mechanism while lifting it up
Remove the Kapton tape
Release the connector for the flex by simply opening it upward.
Release the L-shaped flex from the button bar as well
Removing the button bar is not necessary, but it will be loose and will fall out anyway.
Remove the proximity sensor/front speaker flex
Remove the digitizer flex
The LCD is glued to the front case. Use a pick or similar to release the LCD.
Move the pick, or similar all the way around the LCD to release the adhesive. A gentle prying may be necessary.
Once the adhesive is loosened, use your fingernails, or similar, to remove the LCD from the case.
Fold the LCD to the bottom of the frame.
Here is the LCD removed. LCD and Digitizer are separate piece which makes the a economical feasible repair.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
Works great. It is worth mentioning that there is a slight difference in the disassembly between the black and blue models, as it is easier to leave the flex cable in place with the later. However, the the remainder of the information is directly transferable. Thanks for your contribution!
jensungtan - 답글
