주요 콘텐츠로 건너뛰기
Samsung Brightside Speaker Module Replacement
필요한 것
  1. Samsung Brightside Speaker Module Replacement, Speaker Module: 1 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement, Speaker Module: 1 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement, Speaker Module: 1 단계, 이미지 3/3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Speaker Module Replacement: 2 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement: 2 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement: 2 단계, 이미지 3/3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Speaker Module Replacement: 3 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement: 3 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Speaker Module Replacement: 4 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement: 4 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement: 4 단계, 이미지 3/3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Speaker Module Replacement: 5 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement: 5 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement: 5 단계, 이미지 3/3
    • Detach the LCD connector.
    • Remove the logic board
    • This is the speaker module. In the center is the camera, but it is not part of the module.
  6. Samsung Brightside Speaker Module Replacement: 6 단계, 이미지 1/3 Samsung Brightside Speaker Module Replacement: 6 단계, 이미지 2/3 Samsung Brightside Speaker Module Replacement: 6 단계, 이미지 3/3
    • turn the logic board over. The speaker module is held in place
    • by one Phillips screw
    • and two clips
    • Remove the Phillips screw.
    • It is a M1X2 Phillips screw
    • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
  7. Samsung Brightside Speaker Module Replacement: 7 단계, 이미지 1/2 Samsung Brightside Speaker Module Replacement: 7 단계, 이미지 2/2
    • Turn the logic board around. With the speaker module loose, simply lift it off the board.
    • Speaker module removed.
    • Camera
    • and audio jack
    • are not part of this module and will remain on the board.
결론
oldturkey03
회원 가입일: 09/29/10
782,216 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 963
