주요 콘텐츠로 건너뛰기
Samsung CLP-300 Black Toner Transfer Unit Replacement
필요한 것
  1. Samsung CLP-300 Black Toner Transfer Unit Replacement, Black Toner Transfer Unit: 1 단계, 이미지 1/1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Black Toner Transfer Unit Replacement: 2 단계, 이미지 1/1
    • Pull paper tray out and set aside.
  3. Samsung CLP-300 Black Toner Transfer Unit Replacement: 3 단계, 이미지 1/2 Samsung CLP-300 Black Toner Transfer Unit Replacement: 3 단계, 이미지 2/2
    • Open the front cover.
  4. Samsung CLP-300 Black Toner Transfer Unit Replacement: 4 단계, 이미지 1/1
    • Pull the waste toner container out of the printer using the handle.
    • Make sure to keep waste toner container upright to avoid spillage.
  5. Samsung CLP-300 Black Toner Transfer Unit Replacement: 5 단계, 이미지 1/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 5 단계, 이미지 2/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 5 단계, 이미지 3/3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • At this point you can set the printer aside as you will only need the imaging unit to continue repair.
  6. Samsung CLP-300 Black Toner Transfer Unit Replacement: 6 단계, 이미지 1/2 Samsung CLP-300 Black Toner Transfer Unit Replacement: 6 단계, 이미지 2/2
    • Remove these two screws.
    • Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
  7. Samsung CLP-300 Black Toner Transfer Unit Replacement: 7 단계, 이미지 1/1
    • Carefully pry plastic arm away from main unit.
  8. Samsung CLP-300 Black Toner Transfer Unit Replacement: 8 단계, 이미지 1/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 8 단계, 이미지 2/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 8 단계, 이미지 3/3
    • Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
    • When removing the organic photo conductor take care to not lose the small spring on the back left.
    • At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
  9. Samsung CLP-300 Black Toner Transfer Unit Replacement: 9 단계, 이미지 1/2 Samsung CLP-300 Black Toner Transfer Unit Replacement: 9 단계, 이미지 2/2
    • Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
    • Keep toner rollers level to avoid toner spillage.
  10. Samsung CLP-300 Black Toner Transfer Unit Replacement: 10 단계, 이미지 1/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 10 단계, 이미지 2/3 Samsung CLP-300 Black Toner Transfer Unit Replacement: 10 단계, 이미지 3/3
    • Remove these five screws from the top of the black toner transfer unit.
    • Remove main and smaller z-shaped plates.
  11. Samsung CLP-300 Black Toner Transfer Unit Replacement: 11 단계, 이미지 1/2 Samsung CLP-300 Black Toner Transfer Unit Replacement: 11 단계, 이미지 2/2
    • Remove these three screws from the right end of the toner transfer unit.
  12. Samsung CLP-300 Black Toner Transfer Unit Replacement: 12 단계, 이미지 1/1
    • Remove plastic end piece.
    • Gently pull out black toner roller.
    • Insert new roller in place of old roller turning slightly to fit.
    • Be careful not to pinch small foam square when inserting new roller.
    • Cover new roller with toner by rotating roller by hand.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Heather Howard
회원 가입일: 10/15/14
586 평판
안내서 4개 작성하였습니다
University of Maine, Team 1-1, Diaz Fall 2014 University of Maine, Team 1-1, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G1
3 회원들
안내서 8개 작성하였습니다
댓글 2개
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
Bernd Dreyer - 답글
I need more information for step 12: I removed the old roller. Unfortunately I don't know anymore how exactly the metal discs and the white plastic rings are placed.
Daniel Roller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 33
전체 시간: 3,320
