주요 콘텐츠로 건너뛰기
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: 1 단계, 이미지 1/1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: 2 단계, 이미지 1/2 Samsung CLP-300 Imaging Unit Replacement: 2 단계, 이미지 2/2
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: 3 단계, 이미지 1/1
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: 4 단계, 이미지 1/3 Samsung CLP-300 Imaging Unit Replacement: 4 단계, 이미지 2/3 Samsung CLP-300 Imaging Unit Replacement: 4 단계, 이미지 3/3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Heather Howard
회원 가입일: 2014년 10월 15일
586 평판
안내서 4개 작성하였습니다
University of Maine, Team 1-1, Diaz Fall 2014 University of Maine, Team 1-1, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G1
3 회원들
안내서 4개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 36
전체 시간: 12,701
