주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
부품
지정된 부품이 없습니다.
  1. Remove the back cover by pressing on  the bottom section of the phone and sliding the bottom piece downward.
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Place your finger on the bottom of the battery and lift to remove.
    • Place your finger on the bottom of the battery and lift to remove.
  3. Replace the old battery with the new one.
    • Replace the old battery with the new one.
  4. Insert the spudger underneath the bottom section of the phone.
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Remove the six 4.5mm #000 Phillips screws.
    • Remove the six 4.5mm #000 Phillips screws.
  6. Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Separate the rear case from the phone.
    • Separate the rear case from the phone.
  8. Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  9. Gently lift the camera assembly out of the plastic housing.
    • Gently lift the camera assembly out of the plastic housing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Drew Bentz
회원 가입일: 2011년 09월 22일
565 평판
안내서 5개 작성하였습니다
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 회원
CPSU-MANESS-F11S20G25
3 회원들
안내서 9개 작성하였습니다
Is this for the front facing camera
tracy mann - 답글
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 20
전체 시간: 2,208
