주요 콘텐츠로 건너뛰기
Samsung Captivate Earpiece Replacement
필요한 것
  1. Samsung Captivate Earpiece Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Earpiece Replacement: 2 단계, 이미지 1/1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Earpiece Replacement: 3 단계, 이미지 1/1
    • Replace the old battery with the new one.
  4. Samsung Captivate Earpiece Replacement, Rear Case: 4 단계, 이미지 1/1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Earpiece Replacement: 5 단계, 이미지 1/1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Earpiece Replacement: 6 단계, 이미지 1/3 Samsung Captivate Earpiece Replacement: 6 단계, 이미지 2/3 Samsung Captivate Earpiece Replacement: 6 단계, 이미지 3/3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Earpiece Replacement: 7 단계, 이미지 1/1
    • Separate the rear case from the phone.
  8. Samsung Captivate Earpiece Replacement, Antenna Cable: 8 단계, 이미지 1/2 Samsung Captivate Earpiece Replacement, Antenna Cable: 8 단계, 이미지 2/2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Earpiece Replacement, Camera Assembly: 9 단계, 이미지 1/1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Samsung Captivate Earpiece Replacement: 10 단계, 이미지 1/1
    • Gently lift the camera assembly out of the plastic housing.
  11. Samsung Captivate Earpiece Replacement, Motherboard: 11 단계, 이미지 1/3 Samsung Captivate Earpiece Replacement, Motherboard: 11 단계, 이미지 2/3 Samsung Captivate Earpiece Replacement, Motherboard: 11 단계, 이미지 3/3
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  12. Samsung Captivate Earpiece Replacement: 12 단계, 이미지 1/1
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  13. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: 13 단계, 이미지 1/2 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: 13 단계, 이미지 2/2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  14. Samsung Captivate Earpiece Replacement, Earpiece: 14 단계, 이미지 1/1
    • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drew Bentz
회원 가입일: 09/22/11
565 평판
안내서 5개 작성하였습니다
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 회원
CPSU-MANESS-F11S20G25
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 2,399
