이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Sometimes the earpiece can become damaged or loose and needs to be replaced. Follow this guide to fix this problem.
필요한 것
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Using the spudger slide the tool under the three highlighted connectors to begin disconnection
Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
다른 2명이 해당 안내서를 완성하였습니다.
