이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
Using the spudger slide the tool under the three highlighted connectors to begin disconnection
Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
Gently pull up on the audio jack, taking the attached ribbon cable with it.
The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
다른 2명이 해당 안내서를 완성하였습니다.
