주요 콘텐츠로 건너뛰기
Samsung Captivate Glide QWERTY Keyboard Replacement
필요한 것
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung Captivate Glide QWERTY Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: 9 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: 9 단계, 이미지 2개 중 2개
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: 10 단계, 이미지 2개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: 14 단계, 이미지 3개 중 1개 Samsung Captivate Glide QWERTY Keyboard Replacement: 14 단계, 이미지 3개 중 2개 Samsung Captivate Glide QWERTY Keyboard Replacement: 14 단계, 이미지 3개 중 3개
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: 15 단계, 이미지 1개 중 1개
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jessica Martinez
회원 가입일: 09/25/14
260 평판
안내서 2개를 작성함
USF Tampa, Team 5-3, Mcgee Fall 2014 USF Tampa, Team 5-3, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 540
