주요 콘텐츠로 건너뛰기
Samsung Captivate Rear Case Replacement
필요한 것
  1. Samsung Captivate Rear Case Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: 2 단계, 이미지 1/1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: 3 단계, 이미지 1/1
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: 4 단계, 이미지 1/1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: 5 단계, 이미지 1/1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: 6 단계, 이미지 1/3 Samsung Captivate Rear Case Replacement: 6 단계, 이미지 2/3 Samsung Captivate Rear Case Replacement: 6 단계, 이미지 3/3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: 7 단계, 이미지 1/1
    • Separate the rear case from the phone.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Christopher
회원 가입일: 10/06/11
643 평판
안내서 4개 작성하였습니다
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 회원
CPSU-MANESS-F11S20G25
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 3,571
