주요 콘텐츠로 건너뛰기
Samsung Captivate Speaker Replacement
필요한 것
  1. Samsung Captivate Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Speaker Replacement: 2 단계, 이미지 1/1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Speaker Replacement: 3 단계, 이미지 1/1
    • Replace the old battery with the new one.
  4. Samsung Captivate Speaker Replacement, Rear Case: 4 단계, 이미지 1/1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Speaker Replacement: 6 단계, 이미지 1/3 Samsung Captivate Speaker Replacement: 6 단계, 이미지 2/3 Samsung Captivate Speaker Replacement: 6 단계, 이미지 3/3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Speaker Replacement: 7 단계, 이미지 1/1
    • Separate the rear case from the phone.
  8. Samsung Captivate Speaker Replacement, Speaker: 8 단계, 이미지 1/1
    • Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
  9. Samsung Captivate Speaker Replacement: 9 단계, 이미지 1/2 Samsung Captivate Speaker Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
    • Pull out the ribbon cable.
    • Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Drew Bentz
회원 가입일: 09/22/11
565 평판
안내서 5개 작성하였습니다
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 회원
CPSU-MANESS-F11S20G25
3 회원들
안내서 9개 작성하였습니다
댓글 한 개
It was clear enough to follow, don't know why it got the incorrect text caveat.
I gotta get one of those spudger sets.
Also it did not say where to get the actual replacement speaker.
G Trieste - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 8,740
