소개
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
도구
부품
지정된 부품이 없습니다.
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
