이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
필요한 것
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
다른 2명이 해당 안내서를 완성하였습니다.
