이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You may need to perform this replacement if your Chromebook 2 has a faulty screen, resulting in display issues. Ensure your device is powered off before beginning this replacement.
In order to reduce shock hazard during this replacement, the steps to remove the battery are included as a prerequisite.
필요한 것
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
다른 10명이 해당 안내서를 완성하였습니다.
